Pipe Signal Termination Point Specification Editor Signal Structure Tab
Use the Signal Structure tab to create a new Pipe Signal Termination Point specification or select an existing one.
| Field | Use |
Select Child Signal |
Right-click the specification box and select this option to add an existing Pipe Signal Termination Point specification. |
Create New Child Signal |
Right-click the specification box and select this option to create a new Pipe Signal Termination Point specification. |
