Place Specification Editor Place Configurations Tab
Use the Place Configurations tab to relate Place specifications defined as Site (on the Place Specification editor Properties tab) to Place configurations.
You use this tab for geographic sites only. The buttons on this tab are disabled for all other types of Place specifications.
| Field | Use |
Place Configurations |
Displays the name of the Place Configuration specification. |
Cartridge |
Displays the name of the cartridge project into which the Place Configuration specification is built. |
Select |
Click to select an existing Place Configuration specification. |
Open |
Click to open the selected configuration in the Place Configuration Specification editor. |
Remove |
Click to remove a Place Configuration specification. |
Add |
Click to add a new Place Configuration specification. |
