Place Specification Properties Tab
Use the Properties tab to define the entity type for the Place specification. In the Entity Type field, select one of the following values:
| Field | Use |
Site |
Select to define a place that does not have a single, precise location. See "About the Site Place Type" for more information. |
Address |
Select to define a place using the standard address format to meet your business requirements and national postal standards. See "About the Address Place Type" for more information. |
Address Range |
Select to define a place using groups of related addresses. See "About the Address Range Place Type" for more information. |
Location |
Select to define a place based on geographic references. See "About the Location Place Type" for more information. |
