Place Configuration Specification Editor Place Specs Tab
Use the Place Specs tab to select, add, and remove the Place specifications that use the Place Configuration specifications. The Place Specs tab identifies the Place specifications that use the Place Configuration specification. You must use this tab to relate a Place specification to its Place Configuration specification only when the Place specification and Place Configuration specification need to be in separate cartridges, and the Place specification can exist without the Place Configuration specification. If both the Place specification and Place Configuration specification are in the same cartridge, make the association on the Place specification.
| Field | Use |
Place Specification |
Displays the name of the Place specification. |
Cartridge |
Displays the name of the cartridge project into which the Place specification is built. |
Select |
Click to select an existing Place specification. |
Open |
Click to open the selected specification in the Place Specification editor. |
Remove |
Click to remove a Place specification. |
Add |
Click to add a new Place specification. |
Related Topics
