Populating Drop-Down Lists Dynamically
You can populate the contents of a drop-down list characteristic in three ways:
Static Values: Enables you to populate the drop-down list with a group of values that do not change. See "Populating a Drop-Down list with Static Values" for more information.
Entity Link: Enables you to populate the drop-down list with the names of all entities created from the selected specification. See "Populating Drop-Down Lists with Entity Links Using Existing Specifications" and "Populating Drop-Down Lists with Entity Links Using New Specifications" for more information.
Query: Enables you to populate the drop-down list with the results of a query that you define. See "Populating Drop-Down Lists with Query Results" and for more information.
See "Overriding Values for Drop Down List Characteristics" for information about defining values for drop down lists at the Specification editor level.
