Processing Signal Specification Editor
Use the Processing Signal Specification editor to review the processing signal specification information delivered with Design Studio for Inventory.
Processing Signal specifications define processing signals in the signal structure for a SONET or SDH transmission facility. Processing signals multiplex to, align with, or map to other signals in a SONET or SDH signal structure, but they are not facility or channel signals, because they are not directly associated with a channelized connectivity or channel.
Processing signal specifications are provided in the ora_uim_basetechnologies cartridge. These specifications are associated with Connectivity Signal Termination Point specifications to form the connectivity signal architecture for the SONET and SDH technologies. For information about the signal specifications in the ora_uim_basetechnologies cartridge, including the specification relationships, see UIM Information Model Reference.
When working with the Processing Signal Specification editor, see the following topics:
