Editing A Process Flow
You can edit the activities and transitions in a process flow.
To edit activities:
In the Activities tab, select an activity.
The activity details appear in the Activity area.
Edit the details as necessary. Your changes are effective immediately.
To edit transitions:
In the Transitions tab, select a transition.
The transition details appear in the Transition area.
To replace an activity in the transition, click the Select button in the From Activity or To Activity area.
The Select From Activity or Select To Activity dialog box appears. The list of activities is filtered to prevent you from making invalid selections.
Select an activity, and then click OK.
The dialog box closes and the new activity appears in the transition.
