Changing Palette Settings
You can change the appearance of the palette controls in the Process Flow tab in several ways.
Right-click in the heading of the Activities or Transitions section of the palette, and then select Settings from the menu that appears.
The Palette Settings dialog box appears.
Do any combination of the following:
In the Font area, click Change and select a different font for the palette. Click Restore Default to revert to the original font.
In the Layout area, select an option for the arrangement of items in the palette.
In the Drawer Options area, select an option for how sections in the palette behave.
Click OK.
The dialog box closes and your changes take effect.
