Role Specification Editor Properties Tab
Use the Properties tab to select a role type for the role specification that you create.
| Field | Use |
Role Type |
Select a role type when you create a role specification. Select one of the following:
Available Entity Types |
Displays the entity types that are available for selection. |
Selected Entity Types |
Displays the entity types that have been selected. |
