Ruleset Editor Code Tab
Use the Ruleset editor Code tab to create rulesets in a DRL or GROOVY file.
| Field | Use |
Run Extension Language |
Click to select which extension language to execute at runtime. Your choices are DROOLS or GROOVY. |
Edit Drools Code |
Click to write a ruleset in a DRL file. |
Edit Groovy Code |
Click to write a ruleset in a GROOVY file. |
