Sequence Specification Editor Properties Tab
Use the Properties tab to set a minimum, maximum, and an increment value for a sequence.
Field | Use |
Minimum Value |
Enter a minimum value for the sequence. |
Maximum Value |
Enter a maximum value for the sequence. Retain the default value 0 to define the sequence value as unbounded. |
Increment Value |
Enter an increment value for the sequence. |
