Service Specification Editor Service Configurations Tab
Use the Service Configurations tab to select, add, and remove a service configuration.
| Field | Use |
Service Configuration |
Displays the name of the Service Configuration specification. |
Cartridge |
Displays the name of the cartridge project into which the Service Configuration specification is built. |
Select |
Click to select and add an existing service configuration to the Service specification. |
Open |
Click to open the selected service configuration in the Service Configuration Specification editor. |
Remove |
Click to remove the selected service configuration from the Service specification. |
Add |
Click to create a new service configuration and add it to the Service specification. See "Adding Existing Configurations to a Service Specification" for more information. |
Related Topics
