Specification Editor Specification Properties Tab
Use the Specification Properties tab to enter identifying information about a specification.
Field Use
Display Name
Enter the name that appears in Design Studio editors and in UIM.
Design Studio supports multiple languages for this field. The field adjacent to Display Name displays your list of languages. You can define a display name for any language you select from the list.
If your preferences are set up to work in one language only, the system displays only the [default] option. See “Defining Language Preferences" for more information.
Start Date
Enter the first date on which this specification is valid.
End Date
Enter the last date on which this specification is valid.
System Provided
Indicates whether a specification is provided by Oracle. System-provided specifications enable you to define entity-level characteristics for IP Address Resource Extension, and Property Location Extension entities. Additionally, system-provided specifications can be selected as a specification option on an item in a configuration specification.
Note: You must import the ora_uim_basespecifications cartridge (which includes the specifications for extension entities) before you define characteristics for the extension entities. For information about the ora_uim_basespecifications cartridge, see UIM Cartridge Guide.
Can be assigned to multiple entities
Select if the entity created using this specification can be assigned to more than one instance of a consumer entity at the same time.
Can assign entities that allow multiple assignments
Select if an entity created using this specification can assign entities whose specifications allow them to be assigned to multiple instances of consumer entities at the same time.
Enter Id Manually
Select if you do not want data instances using this specification to have an automatically-generated ID. This check box is displayed only for the entities that are enabled for auto-generation of ID.
The Entity Identification Specification field is not available when you select this option.
Defines the format for an identifier generated for an instance of the entity created from the specification. This option appears only for the specification that is enabled for auto-generation of ID.
Click the Entity Identification Specification to create a new Entity Identification specification.
Select
Click to select an existing Entity Identification specification.
Clear
Click to deselect an Entity Identification specification.
Description
Enter a description of the specification.
