Defining Task Properties
After you create a Task specification, you can specify its properties, including the task duration and a checklist. All of the properties are optional.
To specify task properties:
Go to the Task specification editor Properties tab.
In the Duration (in days) field, enter the estimated duration of the task.
In the Allowed User Group field, enter a user group name to restrict UIM users who can be assigned the task.
Select the Is Milestone check box if you want the task to serve as a milestone in UIM. Milestone activities are displayed as diamonds in Gantt charts.
In the Checklist field, click Select.
The Select Checklist dialog box appears.
Select a checklist and click OK.
The Checklist field is updated.
