Working with Task Specifications
Task specifications define units of work that you can associate with activities in engineering work orders. Task specifications can include Checklist specifications that define steps that must be completed to complete the task.
See "Task Specification Editor" for reference information about the tabs you use to define a Task specification. See "Defining Task Properties" for information about selecting a checklist and defining other properties.
