Working with Network Edge Specifications
A Network Edge specification describes the behavior and attributes of the edges that connect nodes in a network. You create different Network Edge specifications for the different kinds of edges in your inventory.
You can associate a network edge to one or more pipes if the connectivity is known. You can leave the network edge unassociated if the connectivity is not known, or if the reachability is through a dynamic route in another network. A network edge can also be associated to one or more custom object instances that define a type of connectivity not available in the default model.
You create Network Edge specifications in the same manner as you create other types of specifications. See "Creating New Specifications" for more information.
When working with Network Edge specifications, see the following topics:
