Network Node Specification Editor Related Specifications Tab
Use the Related Specifications tab to define and review specification relationships. Only relationships with the entity types listed in this tab are meaningful by default in UIM. If you add specifications to the Others section, you must define custom rulesets that trigger actions or behavior based on those relationships.
| Section | Use |
Other Supported Entities |
Lists specifications of entities that network nodes based on this specification can represent. Network nodes can represent Custom Network Address, Custom Object, Device Interface, Equipment, Logical Device, Network, Physical Device, and Physical Port entities. |
Roles |
Lists roles to which entities based on this Network Node specification can be assigned. |
Others |
Lists specifications of entities that have a customized relationship with entities based on this specification. |
