15 Working with IP Address Resource Extension Specifications
You use IP Address Resource Extension specifications to model content for IP address management. IP Address Resource Extension specifications represent networks, subnets, and IP addresses for both IPv4 and IPv6 address management.
When you define IP Address Resource Extension specifications, you can add characteristics to supplement the default data elements. See "About IP Address Resource Extensions" for more information.
When working with IP Address Resource Extension specifications, see "IP Address Resource Extension Specification Editor" for reference information about the tabs you use to define an IP Address Resource Extension specification.
