Creating a Process Flow by Dragging and Dropping
You can create a process flow by dragging Task specifications to the Process Flow tab of the Process editor.
To create a process flow by dragging and dropping:
  1. While in the Studio Design perspective, open or create a Process specification.
    The Process specification editor appears.
  2. Click the Process Flow tab.
  3. In the Studio Projects editor, click and drag a Task specification into the Process Flow tab.
    An activity is added to the process flow based on the Task specification. You can edit the activity to change its properties.
Related Topics
Editing A Process Flow
