Creating New Orchestration Stages
Orchestration stages are the logical steps OSM must take to ensure that the line items on an incoming order are sent to the proper systems in a sequence that honors any dependencies among the order line items.
To create new orchestration stages:
From the Studio menu, select New, select Order and Service Management, select Orchestration, then select Orchestration Stage.
The Orchestration Stage wizard is displayed.
In the Project Name field, select the project in which the orchestration stage will be saved.
In the Name field, enter a name for the orchestration stage.
The name must be unique among stage entity types within the same namespace.
(Optional) Select a location for the orchestration stage.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field, or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
Design Studio adds the new Orchestration Stage entity to the Studio Projects view and opens the new entity in the Orchestration Stage editor.
Related Topics
