Orchestration Stage Editor
Use the Orchestration Stage editor to specify the other stages on which the corresponding stage is dependent (those stages in the orchestration sequence that OSM must evaluate first), and to specify the order components produced by the orchestration stage.
Orchestration stages are the logical steps OSM must execute to ensure that the line items on an incoming order are sent to the proper systems in a sequence that honors the order line dependencies.
Field | Use |
Description |
Edit the display name of the stage. |
Depends on Orchestration Stages |
Select or create the stages on which the corresponding stage is dependent. Click Select to open the Select Depends on Stage dialog, which contains all of the stages defined in the workspace. Click:
Produces Order Component |
Select the order components which OSM produces during the corresponding stage. The Orchestration Stage editor displays all order component specifications defined in the workspace. Click:
Base Component Functions Search |
Use these fields to limit the number of order components that appear in the Produces Order Component area. The Orchestration Stage editor displays all order component specifications defined in the workspace. Use Base Component to limit the display to a single root-level order component and its dependencies. Use Functions to limit the scope to executable order components (order components associated with a process). Enter a value in the Search field to search for a specific order component. |
Related Topics
