Order Component Specification Editor
Use the Order Component Specification editor to configure the order components that OSM uses to fulfill incoming orders.
Each order component represents a system interaction to a fulfillment system. Order components contain all of the data needed by the fulfillment system subprocess to complete the fulfillment tasks.
This editor contains several different tabs. For details about the fields on each tab, see the following topics:
The following fields are common to multiple tabs in the Order Component Specification editor:
| Field | Use |
Description |
Edit the display name of the order component. |
Namespace |
Select any existing namespace defined in the workspace or enter a unique namespace in which to include the order component. Design Studio uses the last saved namespace as the default. |
