Order Component Specification Editor Component ID Tab
Use the Component ID tab to define an XQuery expression that OSM evaluates against each order item in the order component. OSM stores the resulting value in the ControlData/Functions/FunctionName/componentKey data element and uses it to determine the instance of the order component to which the order item will be assigned. OSM groups all order components that share the same component ID in the same order component instance. For example, you might use the component ID to determine the processing granularity of order items at run time.
See "About Creating XQuery Expressions with Design Studio" for more information about entering information into XQuery controls. See "About Component Specification Custom Component ID XQuery Expressions" for more information about this XQuery field.
