Order Component Specification Editor Provider Function Tab
Use the Provider Function tab to define the provider functions to which the order component and order components that extend it are available.
Field | Use |
Provider Function |
Use this field to indicate the provider functions to which the order component should be available. Do any of the following:
Related Topics
