Order Component Specification Editor External Fulfillment States Tab
Use the External Fulfillment States tab to define the external fulfillment states available to the order component and order components that extend it.
Field | Use |
External Fulfillment States |
Displays the external fulfillment states defined for the order component. Do any of the following:
Details subtab |
Edit the display name of the external fulfillment state. If you are localizing OSM, use the list to the right of the field to set different values for different locales. |
Information subtab |
Enter any additional information about the external fulfillment state that is required by your specific situation. If you are localizing OSM, use the list above the field to set different values for different locales. |
