Order Component Specification Editor Order Template Tab
Use the Order Template tab to configure the control data required to fulfill the order items on the corresponding order component.
| Field | Use |
Order Template |
Displays the data defined for the order component. You must have the required structure for order component control data in the Order Template area; Design Studio automatically adds this structure to the Order Template area. See "About Modeling Order Component Control Data" for more information. The order in which the data is displayed here is the order in which it will appear in the Order Management web client or in the XML API if this task is an automated task. To reposition a data node in the list, select it, right-click, and select Move Up or Move Down. See "About the Order Template Context Menu" for descriptions of actions you can perform in the Order Template context menu. |
Behaviors |
Select a data node in the Task Data area to view the behaviors defined the node or to create new behaviors. Right-click the behavior and select Show Properties to define the behavior information. See "Defining Manual Task Behaviors" for more information. |
