Creating New Orchestration Processes
Orchestration processes define how OSM fulfills incoming customer orders across participating fulfillment systems.
To create new orchestration processes:
From the Studio menu, select New, select Order and Service Management, select Orchestration, then select Orchestration Process.
The Orchestration Process wizard is displayed.
In the Project Name field, select the project in which the orchestration process will be saved.
In the Name field, enter a name for the orchestration process.
The name must be unique among orchestration process entity types within the same namespace.
In the Namespace field, select an existing namespace or enter a unique namespace in which to include the orchestration process.
Design Studio uses the last saved namespace as the default.
(Optional) Select a location for the orchestration process.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field, or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
Design Studio adds the new Orchestration Process entity to the Studio Projects view and opens the new entity in the Orchestration Process editor.
Related Topics
