Orchestration Process Editor
Use the Orchestration Process editor to associate the orchestration process with an orchestration sequence.
Field Use
Description
Edit the display name of the process.
Namespace
Select any existing namespace defined in the workspace, or enter a unique namespace in which to include the orchestration sequence. Design Studio uses the last saved namespace as the default value.
Orchestration Sequence
Configure an orchestration sequence to associate with the orchestration process.
Do any of the following:
  • Click Select to select an orchestration sequence from the list of all sequences defined in the workspace.
  • Click New to create a new orchestration sequence to associate with the orchestration process.
  • Select a sequence and click Open to open the specified orchestration sequence.
See "Working with Orchestration Sequences" for more information.
Invoke Order Transformation Manager
Select to invoke order transformation manager for the defined provider functions when generating the orchestration plan.
Provider Function
Define one or more provider functions that should be invoked when the orchestration plan is being generated.
  • Click Select to select a provider function from the list of all of the provider functions defined in the workspace.
  • Select a provider function and click Open to open the specified provider function.
  • Click Add to create a new provider function to associate with the orchestration process.
  • Select a provider function and click Remove to remove the association between that provider function and the orchestration process.
See "About Provider Functions" for more information about provider functions.
Related Topics
Creating New Orchestration Processes
Working with Orchestration Processes
