Creating New Orchestration Sequences
Orchestration sequences define how OSM decomposes incoming customer orders.
To create new orchestration sequences:
From the Studio menu, select New, select Order and Service Management, select Orchestration, then select Orchestration Sequence.
The Orchestration Sequence wizard is displayed.
In the Project Name field, select the project in which the orchestration sequence will be saved.
In the Name field, enter a name for the orchestration sequence.
The name must be unique among sequence entity types within the same namespace.
In the Namespace field, select an existing namespace or enter a unique namespace in which to include the orchestration sequence.
Oracle Communications Design Studio uses the last saved namespace as the default value.
(Optional) Select a location for the orchestration sequence.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
Design Studio adds the new Orchestration Sequence entity to the Studio Projects view and opens the new entity in the Orchestration Sequence editor.
Related Topics
