Creating New Recognition Rules
You create recognition rules to enable OSM to recognize incoming orders, transform the message into a format that OSM can process, determine whether the message is syntactically valid, and enrich the order data, if necessary.
To create new recognition rules:
From the Studio menu, select New, select Order and Service Management, select Orchestration, then select Order Recognition Rule.
The Order Recognition Rule wizard is displayed.
In the Project field, select the OSM project in which to save the recognition rule.
In the Name field, enter a name for the recognition rule.
The name must be unique among recognition rule entity types within the same namespace.
In the Namespace field, select an existing namespace or enter a unique namespace in which to include the recognition rule.
(Optional) Select a location for the recognition rule.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
Design Studio adds the recognition rule to the project in Studio Projects view and opens the rule in the Order Recognition Rule editor.
