Order Recognition Rule Editor
Use the Order Recognition Rule editor to configure order recognition rules.
Use the Recognition tab to create the recognition and validation rules, associate the rules with an order, and define the relevancy. See "Order Recognition Rule Editor Recognition Tab" for more information.
Use the Transformation tab to define the order priority, reference, and data rules. See "Order Recognition Rule Editor Transformation Tab" for more information.
The following fields are common to multiple tabs or areas in the Order Recognition Rule editor:
Field | Use |
Description |
Edit the display name of the rule. |
Namespace |
Enter the unique XML namespace in which to include the recognition rule. |
Input Message |
Specify the data structure of the incoming order. You can select from the Data Dictionary a previously imported XML structure or a node from a previously imported XML structure. At run time, when a recognition rule evaluates to true, OSM adds this input message to the order template (as an XML data type) to contain the incoming message. |
