Order Recognition Rule Editor Recognition Tab
Use the Recognition tab to create the recognition and validation rules, associate the rules with an order, and define the relevancy.
Field | Use |
Target Order |
Specify an order with which to associate the recognition rule. Every recognition rule must be associated with an order. Click:
Target Order Version |
Select a specific version of an order if you want the recognition rule to recognize an order version other than the default version. To enter a specific order version, deselect the Default check box. |
Fail Order Reason |
Select the Fail Order check box, and enter a reason to display to Order Management web client users if this order has failed during validation or transformation. If the order fails, it is assigned the failed state and placed in fallout. |
Relevancy |
Assign a specific relevancy value to the rule. The value can be any whole integer greater than or equal to zero. The default is 5. Relevancy determines the order in which the OSM server evaluates the order recognition rules at run time. OSM evaluates a rule with a higher relevance before it evaluates a rule with a lower relevance. For example, OSM evaluates a rule with a relevancy value of 2 before it evaluates a rule with a relevancy value of 1. At run time, OSM uses the first order recognition rule that evaluates to true. |
Recognition Rule |
Enter an XQuery expression or a pointer to denote how OSM will recognize the incoming order. See "About Creating XQuery Expressions with Design Studio" for more information about entering information into XQuery controls. For example, in a simple scenario, you may have the recognition based on namespace:
Or, in a more complicated scenario, you might create an XQuery expression that looks for a specific namespace but also interrogates the data within the incoming order. See "About Recognition, Validation, and Transformation Rules" and "About Recognition Rule XQuery Expressions" for more information. Incoming orders that match no recognition rules are marked as failed orders and put into order fallout. See "Defining Order Fallout" for more information. |
Validation Rule |
Enter an XQuery expression or a pointer to denote how OSM will validate the incoming order. See "About Creating XQuery Expressions with Design Studio" for more information about entering information into XQuery controls. For example, the XQuery expression can parse the data to determine whether mandatory fields are populated on the order. See "About Recognition, Validation, and Transformation Rules" and "About Validation Rule XQuery Expressions" for more information. Incoming orders that do not pass validation are marked as failed orders and put into order fallout. See "Defining Order Fallout" for more information. |
