About Order Fulfillment State Composition Rule Sets
Fulfillment state composition rules for the order are defined in order composition rule sets. For orders, there is at most a single fulfillment state rule set per order definition.
A fulfillment state composition rule specifies the composite fulfillment state for the order item when all of the conditions are met. If there are separate situations that can result in the same fulfillment state (for example, use this composite state if either any of the input states is completed, or if none of the states is failed), create additional rules that evaluate to the same composite fulfillment state.
