Order Fulfillment State Composition Rule Set Editor
Use the Order Fulfillment State Composition Rule Set editor to define the composition rules that apply to a particular order.
Field | Use |
Description |
Edit the display name of the order fulfillment state composition rule set. |
Namespace |
Select an existing namespace or enter a unique namespace in which to include the order fulfillment state composition rule. Design Studio uses the last saved namespace as the default. |
Order |
Select the order to which the rules in the rule set apply. |
Composition rule and condition list |
The rules and conditions are evaluated in the order listed: use the Move Up and Move Down commands to ensure that higher priority rules and more restrictive conditions are listed first. The root-level items in this list are the rules, and the child items are the conditions. Do any of the following:
See the following for more information about configuring composition rules: |
