Adding Task Data to a Composite Cartridge View
You can add task data to a composite cartridge view in a variety of ways; for example, by adding the data to the task directly, by selecting existing data from the Order Template or Data Dictionary, or by inheriting data from an extension task.
To add task data to a composite view:
In the Composite Cartridge View editor, click the Task Data tab and model the data as described in "Defining Task Data."
(Optional) Define behaviors for manual tasks as described in "Creating New Behaviors."
(Optional) In the Details tab, select or create a task from which to extend this task.
When creating a composite cartridge view for a creation task, Oracle recommends that you extend from the base task. Creation tasks must have visibility to all of the data required to create the order.
If an order has not already been associated with the task, select an order, or create a new order.
