18 Working with Composite Cartridge Views
Composite cartridge views can define task views, which enable you to define additional task data and views for generic tasks, such as creation tasks and query tasks, which are typically stored in sealed cartridges. After the data is defined, you can contribute it to a composite cartridge build so that the sealed cartridges can access it.
When working with Oracle Communications Order and Service Management (OSM) composite cartridge views, see the following topics:
