Composite Cartridge View Editor
Use the Composite Cartridge View editor to model additional task data to contribute to required tasks, such as creation tasks and query tasks, which are typically contained in sealed cartridges.
The Composite Cartridge View editor uses the same Task Data and Behaviors tabs as the Task editor. For details about the fields on each tab, see the following topics:
