Composite Cartridge View Editor Details Tab
Use the Composite Cartridge View editor Details tab to extend the task definition.
Field | Use |
Extends |
Select or create a task from which this task will inherit data. Using task inheritance, you can leverage existing task data when building new, similar tasks. To remove a task extension, you must manually clear this field. See "About Task Extensions and Inheritance" for more information. |
Order |
Contains the order to associate with this task. If the correct order was not already associated when the task was created, do one of the following:
The order associated with a task determines the overall data set that will be available to the task when you model the task data. |
