Composite Cartridge Editor
Use the Composite Cartridge editor to configure composite cartridge projects. When you create a composite cartridge, you assemble all the component cartridges that make up the solution into a single archive file and deploy the file to the OSM run-time environment.
To access the Composite Cartridge editor, click any composite cartridge entity in the Studio Projects view. The editor contains a number of different tabs. For details about the fields on each tab, see the following topics:
