Composite Cartridge Editor Task Data Contribution Tab
Use the Task Data Contribution tab to define task data contributions to required tasks, such as creation tasks and query tasks, based on additional data modeled in the Composite Cartridge View editor.
When the composite cartridge builds, the task data and corresponding views will be available to the required tasks within the context of the solution.
Field | Use |
Task Data Contribution |
Displays a particular order, process, and task combination to which additional task data will be contributed. Additional task data is modeled in a Composite Cartridge View. (See "Adding Task Data to a Composite Cartridge View" for more information.) Click Add to create a new entry in the Task Data Contribution list using the Task Data Contribution Selection dialog box. In the Task Data Contribution Selection dialog box fields, do any of the following:
When you are finished in the Task Data Contribution Selection dialog box, click OK. Click Remove to delete an existing task data contribution from the list. |
Query Task Data Contribution |
Displays a particular order, role, and query task combination to which additional task data (modeled in a Composite Cartridge view) will be contributed. See "Adding Task Data to a Composite Cartridge View" for more information. Click Add to create a new entry in the Query Task Data Contribution list using the Query Task Data Contribution Selection dialog box. In the Query Task Data Contribution Selection dialog box fields, do any of the following:
When you are finished in the Query Task Data Contribution Selection dialog box, click OK. Click Remove to delete an existing query task data contribution from the list. |
