Creating New Fulfillment State Maps
You create fulfillment state maps to associate external fulfillment states with common fulfillment states. This fulfillment state map contains the mapping definitions that are used to determine fulfillment states that are used in order fulfillment state composition rules, order item fulfillment state composition rules, and point of no return rules.
To create a new fulfillment state map:
From the Studio menu, select New, select Order and Service Management, select Orchestration, then select Fulfillment State Map.
The Fulfillment State Map wizard is displayed.
In the Project field, select the project in which to save the fulfillment state map.
In the Name field, enter a name for the fulfillment state map.
The name must be unique among fulfillment state map entity types within the same namespace.
In the Namespace field, select an existing namespace or enter a unique namespace in which to include the fulfillment state map.
Oracle Communications Design Studio uses the last saved namespace as the default.
(Optional) Select a location for the fulfillment state map.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
(Optional) Select the check box for Create default states. This option creates the following set of fulfillment states in your fulfillment state map:
canceled
completed
failed
inProgress
pending
Fulfillment states can only be defined once per workspace, so if any project in your workspace already has these fulfillment states defined, you should not select the check box.
Click Finish.
Design Studio adds the new fulfillment state map to the Studio Projects view and opens the new entity in the Fulfillment State Map editor.
