Creating New Transformation Managers
You create transformation managers to bind transformation sequences with each domain associated with a specified provider function.
To create new transformation managers:
From the Studio menu, select New, then select Order and Service Management, then select Order Transformation, and then select Transformation Manager.
The Transformation Manager wizard is displayed.
In the Project Name field, select the project in which to save the transformation manager.
In the Name field, enter a name for the transformation manager.
The name must be unique among transformation manager entity types within the same namespace.
In the Namespace field, select an existing namespace or enter a unique namespace in which to include the transformation manager.
Oracle Communications Design Studio uses the last saved namespace as the default.
(Optional) Select a location for the transformation manager.
By default, Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field, or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
Design Studio adds the new transformation manager to the selected project and opens the new entity in the Transformation Manager editor.
