Transformation Manager Editor
Use the Transformation Manager editor to define the transformation sequence for each service domain in a provider function.
Field | Use |
Description |
Edit the display name of the transformation manager. |
Namespace |
Select an existing namespace or enter a unique namespace in which to include the transformation manager. |
Provider Function |
Click Select to select the provider function that this transformation manager realizes. |
Transformation Sequence Bindings area |
Displays the transformation sequence used for each domain associated with provider function. Do any of the following:
Domain |
Click Select to select a domain to bind to a transformation sequence. |
Transformation Sequence |
Click Select to select a transformation sequence to bind to the service domain. |
Related Topics
