Creating New Transformation Sequences
Transformation sequences enable you to define transformation stages, which define the source and target order items and the relationship between them for each step of the transformation.
To create new transformation sequences:
From the Studio menu, select New, then select Order and Service Management, then select Order Transformation, and then select Transformation Sequence.
The Transformation Sequence wizard is displayed.
In the Project field, select the project in which to save the transformation sequence.
In the Name field, enter a name for the transformation sequence.
The name must be unique among transformation sequence entity types within the same namespace.
In the Namespace field, select an existing namespace or enter a unique namespace in which to include the transformation sequence.
(Optional) Select a location for the transformation sequence.
By default, Oracle Communications Design Studio saves the entity to your default workspace location. You can enter a folder name in the Folder field or select a location different from the system-provided default. To select a different location:
Click the Folder field Browse button.
Navigate to the directory in which to save the entity.
Click OK.
Click Finish.
Design Studio adds the new transformation sequence to the selected project and opens the new entity in the Transformation Sequence editor.
In the Properties tab of the Transformation Sequence editor, select input and output order items for the transformation sequence.
Use the Dependencies tab to configure the transformation stages in the transformation sequence.
Related Topics
