Transformation Sequence Editor
Use the Transformation Sequence editor to define the source and target order items and the relationship between them for each step of the transformation.
When modeling transformation sequences, see the following topics:
The following fields are common to multiple tabs in the Transformation Sequence editor:
Field | Use |
Description |
Edit the display name of the transformation sequence. |
Namespace |
Select an existing namespace or enter a unique namespace in which to include the transformation sequence. |
Related Topics
