Transformation Sequence Editor Properties Tab
Use the Properties tab to define the order items that are used for the transformation sequence.
See "Transformation Sequence Editor" for information about fields that appear on multiple Transformation Sequence editor tabs.
Field | Use |
Output Order Item |
Click Select to select an order item specification for the order items to result from the transformation. |
Input Order Item |
Click Select to select an order item specification for the order items to be transformed. |
Related Topics
