Transformation Sequence Editor Dependencies Tab
Use the Dependencies tab to configure the transformation stages in the transformation sequence.
When modeling transformation stages, refer to the following topics:
Transformation Sequence Editor Dependencies Tab Transformation Model Subtab
Transformation Sequence Editor Dependencies Tab Stage Detail Subtab
Transformation Sequence Editor Dependencies Order Item Context Subtab
Transformation Sequence Editor Dependencies Tab Related Order Items Selector Subtab
Transformation Sequence Editor Dependencies Tab Relationship Type Details Subtab
Transformation Sequence Editor Dependencies Tab Stage Condition Subtab
See "Transformation Sequence Editor" for information about fields that appear on multiple Transformation Sequence editor tabs.
Field | Use |
Tree area |
The tree area contains the transformation sequence and each of the transformation stages. Do any of the following:
Related Topics
