Transformation Sequence Editor Dependencies Tab Relationship Type Details Subtab
This subtab is visible when you have a transformation stage selected in the tree area. Use the Relationship Type Details subtab of the Dependencies tab to configure details of the Java classes that implement the transformation stage. This subtab is visible when you have a transformation stage selected in the tree area.
Field | Use |
Relationship Types |
This table shows a list of the relationships that are available to the transformation stage. Do any of the following:
Relationship Type |
Click Select to select a relationship type to be implemented by the transformation stage. |
Implementation |
Do one of the following:
Related Topics
