Transformation Sequence Editor Dependencies Tab Stage Condition Subtab
Use the Stage Condition subtab of the Dependencies tab to configure how OSM determines whether the stage should be run. This subtab is visible when you have a transformation stage selected in the tree area.
Field | Use |
XQuery |
The XQuery tab enables you to configure XQuery-based rules to determine whether the transformation stage will run. See "About Creating XQuery Expressions with Design Studio" for more information about entering information into XQuery controls. See "About Stage Condition XQuery Expressions" for more information about this XQuery field. |
Instances |
Define a Data Instance behavior to obtain data that is not included in the order data and to make that data available to the XQuery expression. Click Add to add a Data Instance behavior. Select the Data Instance behavior, and click Properties to configure the Data Instance behavior. See "Defining Data Instance Behavior Properties" for more information. |
Information |
Describe the intended use of the XQuery expression. For example, you might describe the functionality of a complex expression or provide instructions on its use. |
Related Topics
