Transformation Sequence Editor Dependencies Tab Related Order Items Selector Subtab
This subtab is visible when you have a transformation stage selected in the tree area. Use the Related Order Items Selector subtab of the Dependencies tab to configure details of the order items to which the transformation stage applies. This subtab is visible when you have a transformation stage selected in the tree area.
Field | Use |
Related Order Item |
Do one of the following:
Related Topics
